rotted iron
bob young
Member Posts: 2,177
what would cause a seven year old boiler to have a rotted section? hot water system , copper baseboard , no leaks. lack of proper fresh make up air to boiler room. don't know if this could be a factor.boiler probably somewhat oversized , bypass installed to temper return water. neopreme push nipples o.k. e.g. 75 anyone got the answer ?
Got any
pics??
Have you done a combustion analysis on the unit?
Could still be a pin-hole in the section, just enough to rot it out over that period of time???
Mark H
How many zones in the system? Any zones especially small in relation to the total load?0 -
two zones
one 1 " zone & one 3/4 " zone. one thermostat. commercial bldg.0 -
Do you know
if the EG was taken apart when it was moved into the building? I've had to do this on a few occassions and re-assembling them can be a PITA.
It really sounds like a small leak that just took 7 years to do it's damage.
Mark H
thanks Mark
good possibility it was taken apart. never entered my mind but getting the new one in the cellar was an engineering extravaganza.0 -
That would seem to pretty well eliminate control as a significant part of the problem...0
- 120 Geothermal
- 394 Solar
