PVC pipe for steam
gibson
Member Posts: 15
Is it feasible to replace old steel returns on a steam boiler with PVC pipe? Afterall, the PVC can take the heat, it can take the pressure, and it will never rust. It has some insulative properties, too.
Hmm...
Well, I've seen CPVC rated at 180 F. Is there some rated at 212? If not, I'd be kind of worried if something bad happened and steam got into a return (Murphy is alive and well, and living in the basement), might you not have a problem?Br. Jamie, osb
http://www.dynalabcorp.com/technical_info_pvc.asp
Max operating temperature of 158F, melting point of 176F... falls a bit short of the 212F needed to create steam at sea level atmospheric. Steam under a pound or two of pressure, falls well short. It could certainly be done, but I wouldn't expect it to last any significant length of time.0 -
What I See ........
......with PVC laying on the concrete floor is a crack.0 -
After long deliberation
NO
Ed Carey0 -
ARE YOU FOR REAL...NO NO NO
You should noteven use copper but some people do...
Steel Pipe allows for expansion and contraction...
PVC
PVC Sch40 begins to denature at 140F. Its ability to withstand pressure drops severely as the temperature approaches that number.
It's like a piece of speghetti (sure I spelt that wrong). Its hard until you cook it. It will be come a limp noodle if overheated - useless. Exceptionally bad idea.0 -
Jim
Why should copper not ever be used on steam returns ?0 -
Sure...give it a try...................................
your house first. Are you serious? Mad Dog0 -
Step Away From The Purple Primer !
And Leave the Glue alone while you are at it *~/:)
you didn't conceive of this idea in a small closed room ...:) put the lid back on the cans ... the fumes are like the old bathroom tile glue..it doesn't allow you to do your finer thinking...like don't start focusing on brain surgery or anything along those lines while in that room...
all in fun. you wouldn't want to do that with pvc..it would melt and look like a squished macaroni ...maintaining Pitch would be a bugger...0 -
it creates a battery,
its the cathode and anode setup.
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
