connecting two steam elememnts
David Eisenberg
Member Posts: 5
One of my original steam radiator/convectors was replaced 20 years ago with a steam element convector, 56" long by 6" front to back by 2" top to bottom with 3 pipes running along the length of the element and fins surrounding them. It gets quite hot to the touch but the total heat given off was never equal to that of the original, and it is not adequate for the 17' by 13' master bedroom which it is supposed to heat. I recently thought of attaching another identical element to and above the first one sort of piggy-back. The actual inside diameter of the nipple connecting the elements would be about 5/8". I figure I would get twice as much heat from the combination. Would this be workable?
The problem is these work by convection and temperature difference. Nice cool air is entering the lower coil and being heated, but the second coil has hot coming into it, so it can't give off much more heat. I don't know if this arrangement is possible or not, but you definitely won't get twice the heat.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
