Indirect Water Heater - Water rust or muddy colored
JC_7
Member Posts: 4
We have just noticed (after filling the tub) that our hot water is rusty or muddy colored. The cold water color is fine but the hot is where the discolored water is coming from. Could my indirect hot water heater (17 years old) be the culprit. Could my coils be corroding thus putting rust color in the water? Could the anodes have steel somehwere in the construction of them for the anode material to bond to? The anodes have never been replaced that I can see from the previous home owner. The indirect water heater is a Vaillant brand. I'm very unfamiliar with this heater type and any information for troubleshooting would be appreciated. Maybe a new one should be procured? Thanks for any help. Gary
I had a similar problem last year with an Amtrol. It sounded like there was loose change inside the tank, and the water was very rusty. As it turned-out, a chunk of slag must have formed on the coils and broke loose. It rattled around for about an hour or so while I ran the water. Eventually, the water cleared-up and everything was fine.
Anthony0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
