waterline difference in new boiler
gerry gill
gerry gill Member Posts: 3,084
is my preferred method, but the pedestal will work of course..they both accomplish the same thing.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
  • Dick DeAngelis
    Dick DeAngelis Member Posts: 12
    Since the waterline height in my new boiler is going to be about 22 inches compared to the roughly 47 inches in my existing monster, I take it that I can either create a inverted U type section to create a false waterline or put the boiler on a cement pedastal. Are there any downsides to the pedastal idea, which seems like the simpler way to go.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    waterline
    It depends on what you have for a system. If a simple one pipe, it won't matter much. If two pipe or something like a Hoffman system, it will matter a lot.
    Jamie Hall Member Posts: 27,305
    If it's a Hoffman
    (like mine) try to set it so that the new waterline matches the old one, or as close as possible. They work great, but are a bit techy about water levels.
  • Dick DeAngelis
    waterline
    Thanks for your help with my first question about the waterline in my one pipe system. I now realize that I have to get the waterline above 38 inches to be above the wet return. If I put it at 40 inches then the "A" distance to the main will be 23 inches which is a little below the recommended "A" dimension. Will this cause a problem?
