vacuum steam vents
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,687
makes their #76.
Retired and loving it.
  • David King
    David King Member Posts: 1
    Moline vapor vacuum system
    I have a house where there is a Moline system with a condensinmg loop in the basement. The original vacuum main vents are missing and were replaced with standard main vents. Does anyone know where to get vacuum main vents?
    Jamie Hall Member Posts: 26,855
    except
    you may not need a vacuum vent -- they were really needed for old coal-fired units, and aren't so necessary (if at all!) on oil/gas. You do have Dan's book, don't you?
  • BRIANJ
    BRIANJ Member Posts: 118
    Vacum Vents
    Hoffman does not recommend use of the #76 vent with newer furnaces. If you're using coal it's OK. Contact Hoffman for more information.
