CPVC? Is it an O2 barrier?
Rob_34
Member Posts: 21
I have a person who put cpvc in a slab. Will it work as an oxygen barrier or does he have to use bronze pumps?
Rob
Rob
cvpc
If you can find the mfg. - check their website - ie: ipex.com. I doubt it is oxybarrier - probably should use a hx to separate the systems & temp. control to protect the cpvc.0 -
O2 barrier or not
CPVC is not an approved material for that use as far as I know. That being said, if you can't find info regarding the barrier issue, I'd isolate it with a HX and treat the CPVC side to inhibit sludge and crud formation in it. An ounce of prevention is worth ........0
- 62 Biomass
- 114 Geothermal
