revised p/s loop
Dave_82
Member Posts: 12
Here is a revised schematic of the proposed repiping of my copper tube boiler. The plumber wants to remove the air vents at the ends of the supply and return manifolds and bridge the manifolds together. Does that make sense?
Also, is the placement of the capped tees for a possible future buffer tank (to decrease shortcycling) seem OK? The shutoff in between would be closed when/if the buffer tank is installed.
Thank you.
Dave
Thank you.
Dave
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
