boiler bangs on startup
radioconnection_2
Member Posts: 70
If it shakes the floor, and it was my house, I'd have another pro in there pronto for a second opinion.. Sounds like a delayed ignition problem.
Just got a tuneup on my Weil Mcclain boiler. I have a raised ranch so the boiler in on the first floor under the stairs. It has been loud upon startup for awhile. When they came to tune it up I told them. Now it's just as loud if not louder sometines. Sometimes the floor shakes. They did say that happens when the boiler is cold. When he tuned it up the smoke detector went off. He had the inspection cover loosen. He than tightened it back up and the detector hasn't gone off again. Is that right? I did have a professional do the work, not a friend. Thanks, Butch0 -
Is this a gas
or oil boiler?0 -
Sounds like oil.
What did the inspection include? Did they clean the flue? Check the chimney? Clean between the boiler sections? Adjust the draft? Use a combustion analyzer?
There is a problem. You need to find a new technician to work on your boiler. Start with calling the company back and seeing if they are willing to come out and rectify the problem. It might be a technician that needs some retraining. The company should want to know about this.
Good luck.
It is an oil boiler.0 -
You need a better tech
sounds like a delayed ignition problem. Try the Find a Professional page of this site. If you're in the Baltimore area, call us.
Why does everyone think he needs a new technician? Like none of you have ever had a call back? Call the company back and let them know the problem is now worse. They shouldn't charge you anything for the call unless it requires a part be replaced. Hopefully they send the original tech and maybe a senior or lead tech. Two heads are better than one and maybe the tech will learn something. It could be a bad nozzle or a cracked porcelain.0 -
I Agree with Mike
Don't throw out the baby with the bath water ... Just give a call back to your service provider and let them know it needs a correction . Rumble with a Weil Mclain are common problems outside using a Riello burner or a AFG Becket or better burner. How old is your equipment ?0 -
Because
Sounded to me like the tech that was there told him that the sound was normal on cold start. If that's true, I would suggest a new tech, too.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
