L-vent
Paul_6
Member Posts: 88
is rated for use as a vent connector. some of it is only rated for chimney use.( straight up as opposed to up or horizontal.) it would be a bummer to install it and then find out it was mis-applied. Paul
L-vent
newer code in our area or at least they are starting to enforce. Installed a boiler in a garage and code enforcer wants L-vent,double wall, ran from our oil boiler to the existing triple wall chimney. We are in central NJ any idea what distributers carry this and idea of cost? Any help much appreciated.
The local
"outhouse" didn't even know what L-vent was when I asked for it a couple months ago. Go figure!! Find someone who carries Selkirk-Metalbestos/Eljer or whatever they are called now. I know they make it from doing a little searching. Have fun finding an adapter to join the L to the exsisting chimney.0 -
L Vent
Paul, Re Michel Co. has it, if they have a branch in your area. They have Air Jet. Also, Z Flex has a double wall flex oil connector.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
