replacement unit
BFlanzbaum
Member Posts: 25
Does anyone know of a replacement unit for a First Mechanical Inc., model 3 VP-4 vertical package unit replacement
Thanks In Advance
Thanks In Advance
Never heard of First Mechanical. First Company makes that kind of product. Is it a self contained through the wall heat/cool unit?0
Familiar with First Company but its not like that. Its in a tele-communication CEV0
I know of only 2 companies.
Marvair by Crispaire corp of Cordele GA.
The units I work on are from the early 90's.
One has a very simple use of outside air for cooling. Heating and cooling in one unit. Outside wall mount with only 2 wall openings. All maint done outside.
EngA Engineered Air by Airtex Manf. of Lenexa KS.
Again the ones I see are from 1991.
Some will call them "Overengineered Air as they have fairly complex heat/reheat/low amb operation etc.
Pretty good longevity for both brands and parts were still available as of the last 5 years.
These are on telephone switch buildings.
PS: the operational books I have are so old (90's) they show no web site......imagine that.0 -
Thanks not those either0
Picture of existing?0
Made by First Company. need more information and pictures. Magic Aire may have a replacement0
http://www.firstco.com/Products/Multi-Family-Residential-Products/Single-Package-Vertical-Units
The industry now calls them VTACs, been around forever. Armstrong's Magic Pak is probably the best known. That it ?0 -
not of the unit
https://us.v-dn.net/5021738/uploads/editor/rh/t1bc377hbz19.jpg
I know its not a good picture but this is looking up at the unit from below
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
