Mounting Panel Rad on solid brick wall
Fred Rappuhn
Member Posts: 107
I am mounting a panel rad on drywall covered solid brick exterior wall (with a air space between the interior/exterior brick). The brick is fairly soft and have not had good luck with the brick holding anchors, I was thinking molly toggles to hold the brackets. Suggestions and what size?????
I will remember that one... I usually drill out 1/4" - 3/8" holes and drive in wood wedges. epoxy would help a lot.0
I've had good results over the past few months using the Tapcon Anchors http://www.homedepot.com/p/Tapcon-1-4-in-x-2-1-4-in-Hex-Washer-Head-Concrete-Anchor-75-Pack-24325/100079414
I've used them for both concrete and standard red brick.
Make sure you use the supplied drill bit and a hammer drill so it bores the hole quickly and avoids oversizing it. If you go this route... get the anchors w/the hex heads vs. Philips heads.0 -
If you have drywall, gap, brick, tapcons aren't going to work unless you are going thru furring strips. If you have a gap, I would put blocking in. You can probably, depending on the panel rads, do this where the rad covers the drywall patch.
Never had to deal with drywall and gaps, but did use to deal with soft red clay bricks a lot. I found that using lead wool packed into the hole, then use a conventional lag screw worked excellent. Hole was just slightly bigger than the OD of the lag screw. Stuffing lead wool into the hole through the sheetrock gap may be problematic, but may be worth a shot.
Credit to Dennis Bellanti on the lead wool idea.
METhere was an error rendering this rich post.
I used an epoxy product from Hilti. It looks like a mesh sock, slips into an oversized hole and epoxy injects into it. This allows you to use threaded rod, or whatever fastener you chose.
If you have a gap, a threaded rod would allow you to put a sleeve around it to take up the gap, without collapsing the sheet rock.
The nice feature is it didn't matter if you hit a mortar joint or had an oversized bore, the epoxy expanded into the entire space.
Intended for anchor bolts into a floor, should work on walls.
I agree with Tapcons you need the exact sized drill and don't wobbleBob "hot rod" Rohr
I believe Simpson also makes an old brick anchor.0
What I am dealing with is a soft red clay like brick, that was plastered over and the dry wall was glued to the brick/plastered wall. Expanding anchors tend to bust the brick up and a tap-con does not bite very well. I was originally thinking of a molly toggle to go completely through and grab from the back, but I am very interested in the Hilti epoxy0
Here is the product I was mentioning.
https://www.us.hilti.com/anchor-systems/injectable-adhesive-anchors/Bob "hot rod" Rohr
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
