why bother
lchmb
lchmb Member Posts: 2,997
why would someone need to check the pressure relief valve..or get a tuneup...
SWEI
  • kcopp
    kcopp Member Posts: 4,435
    Ridden hard and put away wet.....
    lchmb
  • EzzyT
    EzzyT Member Posts: 1,296
    Wow
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • Gordy
    Gordy Member Posts: 9,546
    10 more years you could have carried it out in 5 gal buckets.
    lchmbSolid_Fuel_Man
  • Ironman
    Ironman Member Posts: 7,376
    ''As long as it's runnin, it don't need fixin".
    Bob Boan
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,646
    Outta sight outta mind. Sad to say there is a lot of this crap happening in basements across the northeast.
    Taylor
    Steamhead Member Posts: 16,867
    Weil-McLain 68? Steam or water?
    Consulting
  • lchmb
    Hot water. and yes it was the 68 series.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,026
    Holy COW....Mad Dog
  • billtwocase
    billtwocase Member Posts: 2,385
    Usual "O" ring leak. Too bad no one caught that years ago. Could have saved the homeowner some $$$$
  • Steam
    Steam Member Posts: 45
    I had a blown out section on my weil mcclain boiler. Previous owner didn't take care of heating system. Venting sucked, piping was horrible, leak in return. Corrected most of it, with the last small section to be finished before replacing wall & sheetrock.
    Terrible feeling to have a bad boiler, specially when winter is on it's way.
