Another prepiped drop header
EzzyT
EzzyT Member Posts: 1,296
Repiping a boiler that was just put in about a month or so ago.
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
RomanGK_26986764589
  • Paul S_3
    Paul S_3 Member Posts: 1,261
    edited September 2016
    nice job @EzzyT ....its so sad how many hacked steam systems are out there.... customer is lucky to find you....i have an appointment on friday to look at a repiped steam system customer said they ran it and one side of the home doesn't heat....i lost this job to another contractor who was 1/3 of my quote....customer wanted to raise steam main between floor joists to finish basement.....cannot wait to see what they did....
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • EzzyT
    Thanks @Paul S. You ain't kidding see them almost every day. Wow now it's going to cost them at least double to get things right. I get those phone calls to all the time on jobs that I lost to a contractors that completely hacked the system and they want me to fix it with a quick fix I just laugh when they say that
    201-887-8856
  • warno
    warno Member Posts: 229
    So I'm gathering this is what you do? Lol and it seems you do your "prepiping" at night alot of times.
    So when you break down someone else's work do you ever reuse any of their parts?
  • EzzyT
    Correct this what I do. It's the only time I have to spare to do any prepiping.
    If there is anything quality, which most of the time there isn't anything quality
    201-887-8856
    Paul S_3SWEI
  • Paul S_3
    @EzzyT ....how much time do you save on an install prepiping....
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    A couple of hours,
    201-887-8856
  • warno
    I don't know anything about steam but i would like to.
    So why is it that the drop header is so important? Is this a new trick or an old one? It seems you alot of you guys on here replace "basic" piping with these drop headers.
  • EzzyT
    Pick up yourself some of @Dan Holohan books, drop header helps with creating dry steam by allowing gravity to separate the water droplets out of the wet steam entering the header. Size of the header and risers coming off of the boiler into the header is just as important.
    We're trying to slow the steam down and lower feet per second that the steam travels out of the boiler.
    It's a old trick, the dead men used it to get the B dimension (28") from the bottom of the first swing joints to the boiler water line in low clearance applications the drop header allowed them to get the header below the steam mains.
    201-887-8856
  • warno
    I have pumping away which was a pretty good read. I'm more on the hot water side of things and a novice just playing around in my garage at that. Steam scares me abit. Lol
    You do good work by the way. Keep it up.
  • ChrisJ
    ChrisJ Member Posts: 15,737
    Nice work as always Ezzyt.
    I'm starting to learn that steam isn't the only thing being hacked all the time. Seems like every system out there is.
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    CLamb
  • Sailah
    Sailah Member Posts: 826
    I watch a lot of machining videos and one of my favorites is Keith Fenner. His shop labor rate sign is awesome and made me think of you guys out there doing good work.
    It says:
    Shop Labor Rate
    It's not the cost of the repair
    It's the cost of the damage you caused
    And my favorite I have hanging in my office
    Peter Owens
    SteamIQ
    b_bz
  • EzzyT
    Thanks @warno and @ChrisJ.
    There are plenty of hot water systems out there that are hacked and being hacked. I see and work on them all time too.
    201-887-8856
  • EzzyT
    @Sailah those are great quotes
    201-887-8856
  • KC_Jones
    KC_Jones Member Posts: 5,739
    So out of curiosity did you quote the job originally? What happened to the original contractor that messed it up?
    2014 Weil Mclain EG-40
  • KC_Jones
    You must show us!
    Paul S_3
  • EzzyT
    No homeowner posted on here about his disaster, contractor bailed after homeowner asked them to change the boiler since it was way oversized and repipe it properly.
    201-887-8856
  • KC_Jones
    Ah yes I remember that one.
  • EzzyT
    We're stage firing the boiler too
    201-887-8856
  • KC_Jones
    Given the boiler size and the load, it seems you must. It's sad they paid money for what they got. It's good you are fixing it for them. I wish we could find out the name of the contractor who did it so we can steer people away from their hackery.
  • EzzyT
    Yeah I know it is a shame. There's always going to be hacked around
    201-887-8856
