Unistrut Clamps
![Harvey Ramer](https://us.v-cdn.net/5021738/uploads/userpics/999/nS395CYF1LCF0.jpg)
Harvey Ramer
Member Posts: 2,261
Where are you guys buying the rubber or plastic lined unistrut Clamps for CTS size?
are you refering to cushion clamps for uni strut....i buy boxes of 50 from supplyhouse.com.....and my plumbing supply stocks them too for me....i also buy cushion split ringsASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Ferguson stocks them in their DC's (ProFlo branded, less expensive than the big names.)0
Johnstone Supply, probably SupplyHouse online.
The refrigeration suppliers have them down to 1/4 cts size if you want to mount remote air vent linesBob "hot rod" Rohr
Thanks guys!
@hot rod
Yes indeed! Those remote air vent lines are important with you have air vents on top of those big storage tanks. Every vent leaks sooner or later.0 -
I buy from FW Webb as well. We use them extensively on all refrigeration, they are listed by tube OD, so 3/4 cts is referred to as 7/8 cushion strut clamp 1/2 cts is 5/8 cushion clamp etc.
TSServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Harvey, is there an Aireco or united Refrigeration near you?Bob Boan
Air vents above boilers can be a big problem also. They tend to leak down into the most expensive components, control boards, fan motor controls, etc. That is where a vent tube has some real value.Harvey Ramer said:Thanks guys!
@hot rod
Getting back to strut clamps, I'd like to see a good way to insulate them. We just stop the insulation at the unistrut.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I have a United Refrigeration close by. It's a satellite branch. Never seen them on the shelf but i guess ill have to ask them. Supplyhouse.com I guess would be an option as well.0
If you go with a bigger clamp and wrap tape around where the clamp goes, just let the closed cell pass through it. Obviously, it won't grip it as tightly, but usually that's not an issue.Getting back to strut clamps, I'd like to see a good way to insulate them. We just stop the insulation at the unistrut.
Bob Boan
Winchester is a little bit far to go for clamps.
@Alan (California Radiant) Forbes
I have used these before http://s3.supplyhouse.com/images/products/large/hr-724112-1.jpg
Someone makes insulated strut clamps. I saw them advertised but don't remember where. Will do a little searching0
google Cooper Industries they make strut clamps with insulation inserts for 1/2 or 3/4 or 1" wall insulation0
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 2K Domestic Hot Water
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 932 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 3.3K Thermostats and Controls
- 43 Industry Classes
- 17 Recall Announcements
