Wirsbo TruFlow Valve Sticking?
haukeg
Member Posts: 23
I have a Wirsbo 4 valve manifold with TruFlow valves and one of them seems to be sticking when the Uponor actuator opens. It makes a loud banging/clicking noise which is very irritating, see link for a video showing the behavior and fix. It seems to be fixed by manually pushing the TruFlow valve in and releasing it (sometimes it takes many pushes to open), so I believe it is just sticking. Wondering if I need to replace the valve or if there is another fix? Or could something else be going on? Also, my manifold is on the supply side (not sure if that is relevant).
Thanks for any help!
Video of thumping noise on DropBox:
https://www.dropbox.com/s/b1ewayod4rjc2fu/RadiantThumping.MOV
flow direction correct? What about switching the actuators around to see if it the actuator or valve stem.
If it is only one making the noise, maybe just replace the valve mechanism. How is the system fluid?Bob "hot rod" Rohr
Replace the piston actuator port (available from Uponor dealer). They foul and stick on occaision, especially with boiler water that may need treatment.0
Thank you for the responses. I will swap out the valve and see if that clears the issue. Thanks much!0
As Hot Rod said. The manifold is piped backwards. You need to switch the supply and return. Those valves are designed to close off against flow. Not with flow. What you hear is the stem being sucked into the seat. Thunkathunkathunka...been there, seen that. Reversed S&R and problem went away. So dud the customers complaint.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
