Is boiler oversized
leaking
Member Posts: 46
A few years ago I had a Weil McLain steam unit put in a 12 unit apartment. I did a lot of insulating before the guy came out , attic, foamed walls, windows, insulating doors, etc. I think it was replaced by the old units size even though I told the contractor what I did. This year When it was the coldest days in Chicago , below zero at night, near zero to 10 daytime it never ran more than 20 -30 minutes in an hour. Does that indicate an oversized boiler? In maybe 1982 it was colder, it got down to -26 with windchill of - freeze your nuts in 30 seconds. Yes we have not had real bad winters for years. Would I benefit from cutting back on the gas valve? The Weil mc lain also has that dual gas valve that I don't think is hooked up as two stage. I don't have model number with me or I'd post it. Thanks.
I would look into getting the two stage gas valve hooked up so the boiler downfires as pressure starts to build. That could save on gas usage and shouldn't cost an arm and a leg.
3PSI gauge0 -
If it was sized based on the old boiler, without calculating the attached Radiator EDR, it is probably over-sized but the only way to know for sure is to survey the radiators and caalculate the EDR and compare that to the boiler output. There should be a plate on that boiler that states the net Sq. Ft. of steam output.
If it has a 2 stage gas valve, I would definitely have it wireed to work as a 2 stage.0 -
Weil McClain LGB boilers come with a 2 stage gas valve. As supplied from the factory, it will operate as a simple on/off valve. The installer needs to wire in a vaporstat (and a DPST relay if the boiler has 2 gas trains). Your attached EDR needs to be calculated and compared to the steam sq.ft. rating of the boiler.
Provide pics of boiler so we can review near boiler piping and a picture of one of your radiators and we can help you calculate the EDR of your radiators.
20-30 minutes sounds too short of a boiler cycle. My guess is that boiler is oversized and you may need more main venting. What main vents are currently installed? What size and length mains?0 -
Ok great, thanks, that's a lot of figuring for me to do, it will take time. I don't think the contractor did anything except sell me what he could for 26000. I didn't even get a vaporstat on the instal, I've had to learn my uneven heat cures. until I came here a few years ago and got dans books I was running 2-3 lb, now with a vaportat I cut out at maybe 17oz. I had to request a vaportat. The installer is good, they just don't do the numbers. Your in Palatine?0
Palatine Illinois? I'm S side chicago0
northside of Chicago.leaking said:Palatine Illinois? I'm S side chicago
- 85.7K THE MAIN WALL
- 49 Biomass
- 69 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
