Putting system together - pump selection help
knuckleheading
Knuckleheading... tell me more about it
I just did 180' on my original plans, ha!0 -
wiring
Also, any specifics on wiring Alpha vs Bumblebee?0 -
Hydronic Design Studio II
"Siggy's Hydronic Design Studio II - Hydronic Circuit Simulator section is a very useful tool for estimating head loss & for pump selection. I've used it for some time now & find it to be quite accurate. I believe Hot Rod & Mark E are familiar with it. I believe there is a free trial use of it on his web site - hydronicpros.com
John Pughe0 -
I don't see anything for distribution system piping….
and it MUST also be taken into consideration.
Calculate it at worst case (maximum) flow scenarios. And add it to the mini tube loss and boiler loss.
METhere was an error rendering this rich post.
manifold
I plan on 1" boiler piping and 6, 7, 8 port manifolds to 1/2" 300ft pex loops.
Haven't decided on exact manifold brand and model. I have used RHT in the past. Looked at RHT, Rifeng and Caleffi ($$$) too. I like to have temp gauges, air vents and flow meters in my manifold. For some reason you have to go to 1-1/4" Caleffi model to have temp gauges, which is ridiculous.
Still debating SS vs brass for manifolds.0 -
thanks
Thanks for advice. Gonna check it out, dust off the CD of Siggy's book and look into newest Taco software too.0 -
Hydrolink?
Are you referring to something like Hydrolink hydraulic separator?
Wouldn't it require a P/S piping and zone pumps?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
