radiant heating/cooling combi systems???
xmorganx
Member Posts: 23
I've been trying to learn more about radiant cooling systems ( a pretty new concept here). I do a lot of radiant heating, was thinking about a super simple way to integrate radiant cooling. Maybe running a coil through the incoming cold water supply for domestic hot water? Anything to get rid of (or at least minimise) those bloody ducts that are always in the way of my beautiful pipes. Keep in mind that I live in a climate (and city) where a/c is hardly a necessity and is only something I dream of about 4 days a year. Most houses have no existing cooling or ventilation- I thought it could be interesting in retrofits to add ventilation, but make it much smaller so that it only accommodates the necessary changes for health and to leave the cooling to the radiant system (even if it only lowers the T by 1 or 2 degrees C, that's still better than nothing for most people, when added to common-sense passive cooling). Also interested in learning more about combined systems in general for new construction or major renos. Any ideas, thoughts or links to places I could learn more? Thanks
Radiant heat/cool combi
Healthyheating.com . You will be able to research this there . John Siegenthaler just did a webinar this afternoon hosted by Caleffi that was really informative also , should be archived within a few days .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
732-751-1560
Robur
We do it in Europe . I work with Gas Absorbtion Heat Pumps from Robur . The AR unit will Heat and Cool. You can check it out here www.robur.com
Greetings to the US,
Mario0 -
That's Weird
It opens for me. Maybe becuase I copied and pasted from my IPad. It can be found at
www.uponorpro.com
They recently release a Radiant Cooling Complete Design Manual. Actually working on a radiant heating and cooling project right now. Pretty amazing how much cooling you can get out of a floor. About 11 Btuhr sqft in this project.There was an error rendering this rich post.
That link works.
Chris
June 9, 2013
@ 8:49 AM
Contact this user
That's Weird
www.uponorpro.com0 -
11 BTU/hr/ft2
is enough to reduce the size of an air conditioning system (and more importantly, the accompanying ductwork) by a LOT.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
