buderus gb312 880
dr.phil
Member Posts: 3
ran great for 1 yr. now ithas intermit locking fault 8y/590 reset it and runs great for 2 weeks or locks out one a day technician could not find anything . any ideas thankyou !!!!
Codes
I have seen this before check the vent and intake for blocks. Then make sure your gas pressure is correct was there anything new installed in the gas system... That is a psi switch code.
That code is either air supply or flu gas pressure. Or it could be high or low gas pressure. That's not the easiest code to t-shoot with out seeing it...
I have installed about 3 of them units {well the 312 in general not just one size} and they are all still in service, one of which had a problem with ignition but buderus took care of parts and labor...0 -
Codes
Codes
Codes
Codes
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
