? convert push nipple to threaded on WM snug CIBB?
deaner
Member Posts: 6
Is there a way to convert the push nipple on middle sections of WM snug fit CIBB rads so that they can be used as end pieces. I realize that I would have to use blocking for the feet. Thanks G
drill & tap
sure drill & tap , then connect . what could be easier.0 -
Doing:
Just because something might be possible to do, doesn't mean it is a good idea to try it.
There is more than you have noticed about the end sections. They hold the rods that hold the sections together. They have a lot of tapping's for the feeds and the air vents. They also make a way to end the fins.
I shouldn't say anything. Some people will try anything to find out it doesn't work.0 -
baseboard cast iron
I was asking specifically about cast iron baseboard radiators. With this info do you still think tap/dye is not the way to go? The sections that I have already have an upper and lower hole to fit a push nipple. Thanks. G0 -
The same applies:
The same amswer is still in effect.
You can do anything you want. Just not everything you want.0 -
In a pinch
They can be tapped. Why do you want to do this is my question. I have had to due to freeze ups and needing to get the heat on as the end section is toast. I also have sections of New Weil and AmStan I will never get rid of just incase I need them for repairs.Cost is what you spend , value is what you get.
cell # 413-841-6726
reply to charlie from wmass
Charlie,
I have numerous middle sections but no end sections. I thought if there was a way to use the middles as ends it would save me buying new ends. Just exploring my options. Thanks. G0 -
Charlie,
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
