Combustion Testing of Design Gas Equipment
Tim McElwain
Member Posts: 4,625
May 9, 10 and 11, 2012 At the
Gas Training Institute
338 Metacom Ave.
Warren, RI
Cost for the three days is $900
Contact Tim McElwain 401-437-0557 or e-mail at gastc@cox.net
<span style="text-decoration:underline;"><strong>3 DAY SEMINAR</strong></span>
<span style="text-decoration:underline;"><strong>COMBUSTION TESTING OF DESIGN GAS EQUIPMENT</strong></span>
<span style="text-decoration:underline;"><strong> </strong></span>
<span><strong>This is a three day course designed to cover testing of all different kinds of design gas heating equipment from cooking stoves to heating equipment. It also covers the use of Bacharach Wohler and Testo Combustion Analyzers. It includes 3 manuals and actual hands on testing. It includes:</strong></span>
<strong> </strong>
<strong>Characteristics of Gas</strong>
<strong>Gas Combustion</strong>
<strong>Carbon Monoxide</strong>
<strong>Types of Efficiency</strong>
<strong>Determining Input</strong>
<strong>Draft Hoods & Barometrics</strong>
<strong>Flues & Chimneys</strong>
<strong>Burner Adjustments</strong>
<strong>Burner Combustion Troubleshooting</strong>
<strong>Draft</strong>
<strong>Power Venting</strong>
<strong>Combustion Testing Procedures</strong>
<strong>Bacharach Combustion Tester</strong>
<strong>Testo Combustion Tester</strong>
<strong>Wohler Combustion Tester</strong>
<strong>Combustion Efficiency Charts</strong>
<strong>CO Inspection Procedures</strong>
<strong>Design Gas Equipment Testing</strong>
<strong>Combustion Analysis Test Procedure</strong>
<strong>Testing of Actual Equipment</strong>
<strong> </strong>
338 Metacom Ave.
Warren, RI
<strong> </strong>
<strong> </strong>
Road Show
Do you ever take your training on the road?0 -
Yes I will go on the road
I look for a sponsor in an area that will take care of gathering enough folks together to make it worth my while to travel. The quality of what I offer suffers a little when I travel as my training center has everything there that I need for seminar purposes and I can't carry all that on the road. I have had people come and spend a week or even two with me from as far away as Alaska and California. They report to me after they have returned back that the trip was well worth the time and money spent. What I offer is not available anywhere else in the USA. I bring a very good mix of knowledge gained over the years from nine years in electronics in the Navy, learning boilers and furnaces starting at nine years old, a four year college degree in business, 42 years in the preaching ministry and finally 28 years working as a service tech and an instructor.
What is you location?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
