Distance between tee's
World Plumber
Member Posts: 389
Do I understand right The distance is kept close between tees to keep flow from happening in the other circuit if that pump is off? With Primary/secondary pumping. If I move my tee's far enough away to put in a ball valve and aquastat. Will my worst determent be bleed into the other circuit?
Here's some advice...
I wrote a series of articles addressing this and other piping considerations.
http://contractormag.com/columns/eatherton/alternative_energy_interfaces/
http://contractormag.com/columns/eatherton/alternative_energy_interfaces_2/
http://contractormag.com/columns/eatherton/alternative_energy_interfaces_3/
Don't forget to remove the handle of the tweener ball valve or some newby knowitall will close it for you....
Enjoy!
METhere was an error rendering this rich post.
Typically
You should keep them a maximum of 4 times the pipe diameter apart.
example: 1 1/4 common piping should not exceed 5 inches between tees. Might be just enough room for a valve.0 -
tees
check out a company called webstone they already have a fitting of closely spaced tees with a ball valve already between the tees.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
