Header question
acl10
Member Posts: 349
My header connects into the equalizer as seen in the picture. There is no place for the excess water to drain off once it enters the header. Should I cut the header and install a tee with another pipe about 1 ft into the header to drain the water that enters the header and return it to the equalizer pipe?
The header curves as a 2 1/2 and becomes a 3 as can be seen in last picture.
Drip line
Where should the drip line from the header be attched to near the boiler?0 -
you have no header
the drip line question is moot point with how the rest of the piping is.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
