Save money with circs
Great video I found today:
<a href="http://www.youtube.com/watch?v=nseyuagCQsI">[url=http://www.youtube.com/watch?v=nseyuagCQsI]http://www.youtube.com/watch?v=nseyuagCQsI</a>
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,538
    Found it, or produced it?
    Your name is on the YouTube as the author.
    Retired and loving it.
  • Unknown
    edited September 2009
    You are not comparing,
    one VS circ to another here.
    I adore Taco products, and take offense to this sleezy  demo!
    Try representing Taco this way,,, and I would think JW will have something to say to you personally!
  • Dan_65
    Dan_65 Member Posts: 2
    False Marketing
    Instead of trying to bash one of the best pump manufacturers in the world, why don't you try and compare apples to apples. You compare a Grundfoss Alpha to your typical 007. Are you kidding me. What, you didn't want to compare it to a Taco VS. Don't even answer that, cause we all know you're a hack vendor. Don't get me wrong, I use the pink pump as often as I use the TRUE GREEN but you are pulling the wool over the consumers eyes. And to mention that the Taco needs a flowcheck is ridiculous. Have you not heard of the Taco 007 IFC. The IFC stands for integral flow check. Stop LYING to the consumer just to make yourself feel better. Your a joke!!!
    Dan
  • Paul Pollets
    Paul Pollets Member Posts: 3,656
    Misleading Video
    The video misrepresents the alternate product (taco) and should have been compared with either a grundfos 15-42 or another variable speed pump to make logical comparisons.  Viewers looking at the video would infer that Taco is a "bad" pump. This is hardly fair to the manufacturer, who has a superior reputation in the industry.
    I'm sure their variable speed pump compares with the Alpha.  Comparison in technology should be made between the same products, then against assorted fixed speed pumps.  What about a visible flow meter on the piping demo?
  • Joe Mattiello
    Joe Mattiello Member Posts: 707
    Taco VDT
    The Taco VDT pump works the same way.  See attached literature, and compare that The video was not fair to Taco.  Will you identify yourself so we can discuss your brief inaccurate demo?
    Joe Mattiello
    Taco Comfort Solutions
  • DanHolohan
    The user removed the video from YouTube
    Smart idea. He should have thought of that first
    Did I miss something here? The Taco VDT and the Grundfos
    Alpha are quite different.
    With the Taco you set up a desired delta T and it is
    calculated by the sensors installed, very nifty in special applications.
    The Grundfos Alpha you select a characteristic you wish the
    circ to follow, also very nifty from a simplicity aspect.
    The similarity would be they employ VFD technology and a
    little computing power to produce a final output.
