1-1/2\" TRV?
R. Kalia_8
Member Posts: 54
Any way to get a 1-1/2" TRV?
I know I could change the pipe instead, but that would be very difficult in this case.
Tunstall Associates
has a kit that will turn an angle valve into a TRV, that is, assuming you have an angle valve of that size. Otherwise I do not know of a 1.5 inch TRV, personally.0 -
Yes, looking for Tunstall led me to Macon Associates and they make these conversion kits:
http://www.maconcontrols.com/ezcht901.html
Probably complicated and expensive, but still, the first potentially useful item I have found. Thanks!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
