Controlling water velocity.
edward goodridge
Member Posts: 21
Hello-Will somebody tell me if a full-choke ball valve is the best way to regulate water velocity in a hot-water home heating system. This is 1-1/4" pipe. Thanks.
Best way to control flow would be a balancing valve. What are trying to control? Velocity would best be controlled by pump and pipe size.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
