radiant off a steam boiler
Phil_6
Member Posts: 210
Lately I have gotter a few people with steam boilers looking to add some radiant heating.What is your usual solution to this if there is no coil to use? I did one a few years ago with some sort of big heavy heat exchanger which worked out ok but I remember as a pain to do. Is there an easier way?
I never
tried it but I think if you came off the bottom and mid section or dip tube to a Taco Mixing Block that might solve a lot of issues, 'cept mud of course. Or you could install a 2 coil Amtrol Boilermate using 1 coil for the radiant.
funny you should mention Taco..
I just opened my mail and there's an ad in a trade mag for something called the taco X-Pump Block, like the mixing block but with a heat exchanger built in. I could connect it to the water heater and not mess with the boiler...gotta go check it out...0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
