Moving boilers
bob_34
Member Posts: 40
i have 2 lectro trucks. one about 23 years old that worked really well. i bought a new one a year ago and i don;t like it. too top heavy. at least 30 pounds heavier than the old one- all up high and the shoe has a slippery design for holding on stair treads compared to the old unit. and the movement is too sudden compared to the older model. if i had to do over i would get the aluminum powermate. to get in and out of my box truck and over raised cellar bulkhead entrances i use 2 plastic warehouse pallets- about 30 pounds each with plywood top. i can spin the boiler lectro truck load around right on the pallett. very slick and the palletts stack and slide tipped up in and out of the truck. the palletts are from northern tool and i think they were about 75 bucks each.
I was wondering how most people move boilers inside and remove them. We have used a variety of methods including outsourcing but none have been satisfactory. I am thinking about an electric hand truck but have no experience in choosing. On paper, the Escalera looks good but I wonder how it works in the real world. I would appreciate any input.0 -
IMO
The Escalara falls short. It only lifts 9" at a time, a real PITA for loading onto or off from the truck. Also, I think it could break the nose of a step and slip back down, kinda scary thought.
I have a Lectro Truck. It lifts about 40" in one pull. Does stairs with ease. Very solid. Costs more, but you get what you pay for.0 -
trukin
We have an elektra truck way to go worth the dough . just spend it want proof as to why ? let me show you the MRI of my back
Bob
Is the new lectro truck steel or aluminum?0 -
Lectro truck
I own the aluminum Lectro truck (capacity 1500 lb.) but I would recommend the steel model if others besides yourself will be using it. The aluminum is lighter (165 lb.) but won't take the abuse that the steel will. Am very pleased with it- works in most all situations although it can be very tough to negotiate on landings between stairs. Wish I'd owned it twenty years ago.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
