Core removal tools. What brand?
What do you carry and find works best for you? I've seen all kinds of complaints from every brand out there. Typically I go for Yellowjacket stuff, but even theirs has complaints.
I've been happy with my pair from appion0
I just picked up four C&D valve tools on Friday--Johnstone H25-597. I'm gonna vac down a 60 ton condenser, hopefully this week.
I've used this brand before, no problems yet. I every got the pick & thread chase for it, just because.
You don't always need it, but when you do, nothing else will work.
60 tons? is that all?ratio said:I just picked up four C&D valve tools on Friday--Johnstone H25-597. I'm gonna vac down a 60 ton condenser, hopefully this week.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Appion here. They come in 2 flavors , 1/4 and the purple 5/16. The 5/16 accept 1/4 inch hoses so they are sort of dual purpose crt / adaptor.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
A thread chase for Schrader fittings?
ChrisJ,come on!!!!! Get the tool!! You know that you REALLY want it. At WORST,its a cool looking tool. I have YJ.0 -
I'm spending some cash to buy the Yellowjacket liquid filled 3 1/2" gauges to convert my Brute II's over to 410\22. So already buying some cool tools. Oh, and let's not forget the new ball valve end hoses, of course.Techman said:A thread chase for Schrader fittings?
Mine have only been used once, but they're something stupid like 134A\404A\407C.
As soon as I saw they had these nice 3 1/2" liquid filled gauges for it I was sold.
I'd suggest getting the plain ends, then get separate ball valves/low loss/whatever fittings. I've had too many of them leak over the years to want then permanently attached to the hose. I usually roll with low loss on the red & blue, & a valve on the red & yaller. Lets me switch bottles out without purging the yaller, & empty liquid outta the red without unnippling from the teat. Lazy!
& it is a big'un, biggest condenser I've worked on to date. Two big MAUs, about 25' tall, 1.5 million BTUh heat, 60 tons of cooling. All the fancy controls got deleted from the scope, so they're basically big splits now.
Oh, & if you get the fancy tool, be sure to get the one with the ball valve, the other style is just a rubber gland that gets pushed into the throat of the tool by a screw. I don't see how it could possibly hold a vacuum.
1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
