Tankless DHW over 100% Efficiency?
Maybe by the AFUE but not in real life. We all have to give up something to get some thing.0
Yup. Second law of thermodynamics. The energy or work out is always less than the energy in...
What you are missing is that efficiency is -- or should be --- properly measured by taking the energy content of the fuel used and dividing that into the energy content of the useful output. Efficiency on things such as boilers and water heaters is almost always actually determined indirectly, rather than by direct comparison of the energy input and useful heat output. This can give rise to some very strange numbers indeed...
In the example you cite, if you calculated the efficiency and neglected the heat input from the warm intake air, you could indeed get apparent efficiency numbers over 100%. In fact, if you didn't really need your output water temperature to be greater than the air temperature, you could happily get an infinite efficiency!Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
I believe it's only that efficient on low fire. So if you preheat your hot water with solar you could be up to those numbers.
I only use about 5 therms a month for hot water in the summer time and some light cooking. My service charges are more then my NG charges.
That's with a Navien combi boiler0 -
You are correct that a heat pump water heater that gets it's energy from the indoor air is deceiving.AJinCT said:I know AFUE is completely hosed up as an efficiency measure, due to losses in the boiler to the unconditioned space and all of that.
And yes, the Second Law determine that you can't have efficiency over 100% from a combustion efficiency perspective alone.
But in the case of a tankless water heater, it would effectively be sucking heat out of the outside air in the process of heating it, which I'm thinking could get the efficiency based on fuel in and heat out slightly over 100% in exactly the right conditions...
Yes, true, that would just be a giant radiator in the air at that point. I'm cooking the books the same way that you say a heat pump might be 380% efficient, or an HPWH is 285% efficient by not counting heat from the air, since it is not purchased fuel like electricity, NG, or LPG.
A heat pump that get's it's energy from any source outside the heating envelope is a real number.
I always feel like the true energy used needs to reflect what it takes to get it there. Electricity is one of the worse with approx 70% generation and transmission losses.
All fuels have some cost associated with processing and transportation."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
You cannot get 100% efficiency... nor 100%+
Simple physics.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
