digital thermometer for Dunkirk Steam system
Michael G
Member Posts: 23
There seems to be some back and forth as to whether or not to use a digital thermometer in our home for our steam system. As Mad Dog recommended to us years ago, we use the T87 but are thinking that it might help to have digital with the ability to adjust for times of day, etc. Any thoughts or recommendations would be appreciated!
Michael 10706
Michael 10706
I use a Visionpro 8000, and it works fine when set for steam (1 cycle per hour).
I've kept a couple of the T87 as backup.Br. Jamie, osb
I will second that. I installed the vision pro last year and I actually like it, as much as one can like a thermostat. The CPH setting is key and is the reason I think some shy away from digital on steam. As long as that setting is available I don't see anything wrong with using digital on a steam system. I use 2 CPH, but I also have the EcoSteam controls "running interference" so I get an actual 2 CPH exactly.Jamie Hall said:I use a Visionpro 8000, and it works fine when set for steam (1 cycle per hour).
I've kept a couple of the T87 as backup.0 -
Even the lowly HW 5000 series has a cycle setting from 1 to 12 per hour. I assume the 6000 series that is programmable also may have that option.
I use the 8000 series where the screen needs to be locked and "hold" could not be applied for days at a time0 -
It does.JUGHNE said:Even the lowly HW 5000 series has a cycle setting from 1 to 12 per hour. I assume the 6000 series that is programmable also may have that option.
Consulting0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
