Leaking water from AC
I've an AC that leaking water. Any idea how to fix it permanently.
  • RobG
    RobG Member Posts: 1,850
    We need allot more info than that. Where is it leaking from? What type of A/C unit is it? Can you post photos?
  • Jayt
    Jayt Member Posts: 5
    I've split AC and its leaking from AC unit
    Jamie Hall Member Posts: 23,327
    If it's water it's likely condensate from the air -- there should be a catch pan and a drain. Have you checked to see that any catch pans are clean and that all the drains are open?
    Zman
  • Jayt
    @Jamie Hall Thank you for your valuable suggestion. Issues solved now.
