Vision Pro 8000 thermostat
Silvion
Member Posts: 26
I have a vision pro 8000 for steam heat. I have it set to 1 cph per hour cycle. However went it calls for heat when there is a 2 or 3 degree setback it keeps running and short cycling until the temp is met. Is there any other setting I need to adjust. System type I set to 3 Heat only. Its a oil steam furnace. I just want it to run once for the hour fill radiators with heat then shut off.
sil
sil
Any thermostat setting is just a pre-programmed "guess". It's not an accurate setting. Short cycling is typically caused by an oversized boiler, undersized venting, or improper piping.0
or, sometimes, improper pressure settings. Though less often than a somewhat oversized boiler or undersized venting, which are the two most common culprits.JStar said:Any thermostat setting is just a pre-programmed "guess". It's not an accurate setting. Short cycling is typically caused by an oversized boiler, undersized venting, or improper piping.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 967 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
