Thermostat or not
bokaba
Member Posts: 5
I was planning on getting an oil-filled radiator space heater for my bedroom. Would one with a digital thermostat be better than a manual thermostat (the dial with numbers)?
Probably not really...
in principle, the digital one could maintain a slightly tighter temperature range -- at the radiator. But there wouldn't be much difference, practically speaking. Calibration might be a little different, too -- but you're going to set the thing at a comfortable temperature, so what the actual numbers say isn't important.
Digitals do look cool, though...Br. Jamie, osb
More importantly
the Chinese manufacturers have been aggressively cheapening these things for the past decade or so.
Try to find one with seven fins (most have five) and look out for cheesy feet or wheels.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
