Thermostat or not
bokaba
bokaba Member Posts: 5
I was planning on getting an oil-filled radiator space heater for my bedroom. Would one with a digital thermostat be better than a manual thermostat (the dial with numbers)?
    Jamie Hall Member Posts: 23,162
    Probably not really...
    in principle, the digital one could maintain a slightly tighter temperature range -- at the radiator.  But there wouldn't be much difference, practically speaking.  Calibration might be a little different, too -- but you're going to set the thing at a comfortable temperature, so what the actual numbers say isn't important.
    Digitals do look cool, though...
  • SWEI
    SWEI Member Posts: 7,356
    More importantly
    the Chinese manufacturers have been aggressively cheapening these things for the past decade or so.
    Try to find one with seven fins (most have five) and look out for cheesy feet or wheels.
