one pipe steam
happyshaw
Member Posts: 2
I have a one pipe steam heating system and two radiators on the second floor that just get to hot.I have been looking at these macon 1/8 inch steam vents that regulate temperature buy way of a thermostatic valve.The inlet piping is 1/1/2 and I really don't want to change the angle rad valve at the floor,im just not sure this little air vent valve is gonna do the job any thoughts? whats gonna work better? 1/1/2 thermostatic valve or this 1/8 inch thermostatic air vent valve
Is this the one your looking at?
I assume your looking at this -
http://www.tunstall-inc.com/wp-content/uploads/OPSK12041.pdf
The way they work is to stop steam getting into the radiator by blocking the air from leaving the radiator. If the air can't leave the steam can't get in.
What kind of air vents are on the radiators now? It might be worth trying Hoffman 40's first because they cost a lot less than a TRV does. If they still get too hot you can install the TRV's.
3PSI gauge0 -
vent valve
Air vent valve is the only one recommended for one pipe. You're not supposed to modulate the intake on a one pipe. That angle valve is strictly for full open or completely closed. There's thermostatic vent valves with an integrated vacuum break.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
