To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
below slab floor drains
AK_ToddAK_Todd Member Posts: 1
Couple questions on floor drains. I've seen that a siphon can develop if your pipe extends too far past the p-trap without venting. I know there are lots of such drains without vents so is this really an issue or is there a special fix.
For those floor drains in the middle of the garage or in the mechanical room, do they need cleanouts? I ask because I've seen several drains with no cleanouts. I have seen drains with the a cleanout passage (that go to the other side of p-trap) in the side of the drain bowl. Other than one of these drains or a whole-house p-trap, what options do I have for small (2") floor drains clean-outs?
  • ZmanZman Member Posts: 3,194
    Venting
    Drains in the middle of slabs are required to be vented. The vents branch off close to the trap and go to a nearby wall. There are commercial traps with cleanouts. Why do you need one? Zurn makes quite a few. Plumbing waste and vent is pretty involved. It is not something you learn quickly.
    Albert Einstein
  • HillyHilly Member Posts: 336
    in Canada..
    Up here a 3" P-Trap could be as far as 12' from its drain connection and not require a vent.
    still needs vent
    That is a 2" drain which means that there will be a vent take off required within 8' of that in some form, be it individual, wet....
  • icesailoricesailor Member Posts: 7,265
    Trap to vent distances:
    In MA, a 2" trap outlet can't be more than 6' developed from a vent and 3" is 8'.
    Minimum drain size under a slab is 3" with short runs of 2" allowed.  You can "Wet Vent" a floor drain trap/drain with a sink drain, tied in closely to the trap where waste water from the sink will splash over into the FD trap so you won't need a trap re-sealer.
    If the trap is in a garage, it is supposed to rum through a oil and gasoline interceptor.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
