Propane as fuel
fishpimp
Member Posts: 2
Howdy,
My wife and I have purchased 20 acres in rural Island Co. We will start building in one year. We will not have access to natural gas. I plan to install radiant heating and would like to use propane (also for cooking and hot water). Are there boilers that can use propane?
The home will be less than 2,000 square feet. Will I need a large fuel tank?
You bet
Most natural gas models are available in propane versions. For radiant heating, high efficiency units work very well as they love the low water temps.
If you insulate well and install good windows, a 500 gallon tank should be plenty.
This site has tons of good info.
Welcome
Albert Einstein0 -
LPG
Some areas have better LPG distribution than LP.0 -
Good info.
Thanks for the help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
