Electric boiler
Zman
Member Posts: 7,569
Is there any downside to controlling a large electric boiler with outdoor reset?
I am working on an "always on" commercial system that has a tendency to overshoot.
Can you damage an electric boiler by turning down?
Thanks,
Carl
Thanks,
Carl
Albert Einstein
Albert Einstein
how are you turning down?
Most large electric boilers I've seen have multiple elements and some kind of switching. The newer ones have TRIAC controls, which can be retrofitted to almost anything.0 -
Control
Swei,
I have seen a graph of the boiler's energy use. It appears to be a multistage setup with multiple elements. I will open it up and figure out what controls the beast on my next visit.
Albert Einstein0 -
Assuming it has a control input
an off-the-shelf ORC (possibly with some kind of adapter if it's an older interface) should get you there pretty easily.
If not, I'd replace either the low voltage side or everything in front of the elements depending on what was in there.
http://www.viconics.com/electric_heat.php
http://indeeco.thomasnet.com/category/all-categories-indeeco-controls-controls0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
