Snowmelt Design
Korean_Redneck
Member Posts: 1
I am working on a Senior Design Project on a snowmelt system for a runway. I need some help figuring the heat required in the pipes and how far apart the pipes need to be to effectively melt the snow. Also, I need to know if I need a reheater or additional heat exchanger in order to keep the required temperature. The sample size of the runway I am using is 150 ft wide by 1000 ft long.
Info to take acct
1. Snowfall rate up to 3.5 in/hr
2. Average air Temp at 16 F (-8.89 C)
3. Layers -> Pipe - 2 in. NWT Concrete - 2 in Asphalt
4. Pipe is PEX (HDPE)
5. Mixture in pipes is propylene glycol and water (40%:60%)
6. Pipe - ID - 1 in, OD - 1.125 in
7. Pipe will run parallel with the runway
Thanks!
Info to take acct
Thanks!
Starting point
This should help get you started
http://www.uponorpro.com/~/media/Extranet/Files/manuals/SIMeltMan2003.aspx?sc_lang=en"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
