smoke detectors
Paul S_3
Member Posts: 1,292
does anyone have any tips or wiring diagrams for common smoke detectors.....my boss is sending me to a job where it failed inspection because of a in correctly wired smoke detector....i know they usually break the "R" before it hits the thermostat....but are they new ones that i would have to power from the air handler??.....any insight would be helpful...
thanks PAUL S
thanks PAUL S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
A little more?
Are you talking about commercial duct sensors? Household smokes? Flame rollout?
I little more would help.
Albert Einstein0 -
ZMAN
Commercial duct sensor....they installed a air handler the other day ....and they are sending me to wire it up....
PAUL SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 87.4K THE MAIN WALL
- 15.8K Strictly Steam
