furnace sizing
Tomahawk
Member Posts: 2
in Gas Heating
Does anyone have a simple scale for sizing furnaces for residential use
Sizing:
Easy as pie.
If it's a hot water system, do an accurate heat loss calculation of the structure. Sizw the boiler accordingly.
If it is an existing steam system, measure up all installed radiators, compute the EDR of the radiatiors, and size the boiler to the EDR.
Easy.0 -
Tomahawk are you looking
for boiler sizing or Forced Warm Air Furnace sizing?0 -
Scortched Air
If it is a furnace, you need to preform a load calculation (Manual J). Also duct work sizing and design is very important. A Manual D is used for duct sizing and design.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
