Outdoor Reset
wrxz24
wrxz24 Member Posts: 301
Any recommendations for an outdoor reset that can be used to adjust both baseboard/ DHW  and in slab radiant heat.
I have 3 way manual adjustable mixing valves for the floor heat.  Would I need to purchase new mixing valves that are adjusted by the outdoor reset.
Thanks in advance.
  • Zman
    Zman Member Posts: 7,569
    Tekmar
    Tekmar makes great products for this application. I would put the DHW on priority then use a motorized mixing valve controlled by the tekmar for the radiant . Many manual valves can be adapted with a motor.
    Albert Einstein
  • wrxz24
    honeywell am
    is there a particular control system/motors  for the use with these types of mixing valves ?
  • kcopp
    kcopp Member Posts: 4,433
    Before you....
    do that..... what do you have for a boiler? Baseboard usually is not mixed down.
    The valve I like to use is the Taco iValve.... it does outdoor reset and mixes all  in one easy package.
  • wrxz24
    Smith GV100
    with baseboard and in floor radiant (concrete slab).
