Outdoor Reset
wrxz24
Member Posts: 301
Any recommendations for an outdoor reset that can be used to adjust both baseboard/ DHW and in slab radiant heat.
I have 3 way manual adjustable mixing valves for the floor heat. Would I need to purchase new mixing valves that are adjusted by the outdoor reset.
Thanks in advance.
Thanks in advance.
Tekmar
Tekmar makes great products for this application. I would put the DHW on priority then use a motorized mixing valve controlled by the tekmar for the radiant . Many manual valves can be adapted with a motor."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
honeywell am
is there a particular control system/motors for the use with these types of mixing valves ?0 -
Before you....
do that..... what do you have for a boiler? Baseboard usually is not mixed down.
The valve I like to use is the Taco iValve.... it does outdoor reset and mixes all in one easy package.0 -
Smith GV100
with baseboard and in floor radiant (concrete slab).0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
