Kitec Tubing and fittings?
4Johnpipe
4Johnpipe Member Posts: 486
I came across a job where I was referred. The contractor(?) installed Kitec tube and brass fittings in a radiant/ baseboard heating system about a year and a half ago new home. The tubing is not common here. I looked it up and came across a lot of information regarding a class action suit regarding this material. Can anyone confirm the use for this product. I can not determine if 180 degree boiler water is approved the parent company IPEX seems to have discontinued the entire line. I am at a loss seeing this installed approximately 2 years after all the litigation and problems with the product.
LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com
Welcome
It looks like you're new here. Sign in or register to get started.
  • Brad White
    Brad White Member Posts: 2,399
    My understanding is that
    the issues were dezincification, crumbling fittings but only on domestic water systems, not on heating systems.  Anyone hear otherwise?
    (I have about 200 feet of 5/8" Kitec, a manifold fitted for 5/8" and a host of 5/8" Kitek K2 compression fittings, but not enough to complete a few radiator hook ups. Anyone have any to spare/sell? I cannot find them either.)
    But I can see the issue, once bitten, better to remove the product entirely when you cannot control the final installation.
    -Ernie White, my Dad
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    No issues with closed loop systems that I am aware of...
    I remember Paul Pollets relating a story about high temp potable DHW/space heating system failing up in Washington state. The tube was blistering as I remember.
    I have MILES of that stuff out there, and other than having the compression fittings that un did themselves, had no issues.
    ME
  • Ironman
    Ironman Member Posts: 7,713
    Same Here
    No issues on hydronic systems. There are several manufacturers whose pex-al-pex is made to the same spec's. We switched to Roth and have interchanged the fittings and pipe with Kitec and had no problems. Just fired up a job with 4500 feet of in slab. Works great.
    Bob Boan
  • meplumber
    meplumber Member Posts: 673
    Ironman is right.
    The Roth fittings seem to work.  Had no problems with closed systems.  The lawsuit delt with domestic potable water.
  • Hilly
    Hilly Member Posts: 429
    not just DW systems
    I have seen failure on Hydronic systems here in NL, Canada. Insurance companies wont offer home insurance to anyone with the pipe in the home any more. I have only ever seen Kitec installed on one DW system ever in these parts. I have been on several systems where the hydronics had to be re-pipe before sale of a house. And I have witness many leaks on the pipe and fittings. Compression pex-al-pex, crimp pex-al-pex, cheap compression generic. So in my experience this is not a DW only problem.
  • Paul Pollets
    Paul Pollets Member Posts: 3,668
    Kitec
    Here's a pic of some serious de-zincification on a Kitec piping system to wall convectors using a water heater (open system) as the heat source.
Welcome
