To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
grease buildup in drain
thanks, i'll give it a try--nbc
  • nicholas bonham-carternicholas bonham-carter Member Posts: 6,367
    anyone had experience with some preventative procedures to alleviate grease build up in restaurant drains. i know that lye [sodium hydroxide] plus grease = soap, but does it work in drains?--nbc
  • mtfallsmikeymtfallsmikey Member Posts: 765
    Try this:
    Natural Enviro 1000 - Grease Trap Solution...
    www.naturalenviro.com
    This is a bacterial type product.Does a fairly good job.No lye.
    I used to use Chloroben PT. don't know if it is still available or not.
  • scrookscrook Member Posts: 598
    Install...
    a grease trap and have it cleaned on regular intervals. Is a grease trap not a code requirement in your area for this application/use?
    Lye (sodium hydroxide) based crystal drain cleaners should be effective on grease deposits however.
  • an old wrench pulleran old wrench puller Member Posts: 73
    I like this stuff
    http://www.zepcommercial.com/products.asp?category=11
    Any good supplyhouse will have a good non- acid cleaner. regular use is the key.
  • mikemike Member Posts: 675
    yeah, g traps in restaurants
    i thought they're national code
  • Rich KontnyRich Kontny Member Posts: 562
    Bio-Clean
    has environmentally safe products for both residential and commercial application. A time proven product line
    Good to see you again, Mike!
    How's things at M & A?..I see some of your guys coming bck up the road in the afternoons.
  • Jamie HallJamie Hall Member Posts: 6,010
    if it isn't
    code in your area to have a grease trap on a commercial kitchen (e.g. restaurant, school, etc.) it should be. In any event, do install one -- at the very least on the dishwasher drain and any sinks used for cleaning or dishwashing.
    And Then Make Sure It Is Cleaned Out! Can't tell you how many grease traps I have inspected which were never cleaned out.
    You'll need a drain cleaner as the other guys have mentioned to get rid of the gook that's already there...
    Trust me: you'll have much better drains -- and the guys at the sewer plant will be very appreciative! Of course, if you have a septic tank, the guys who clean it will hate you, as they won't have to pump it so often!
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
