older pressure gauge
gibson
Member Posts: 15
I have a one-pipe steam system with an oil-fired Crown boiler. The pressuretrol is set to cut-in at .5 with a differential of 1. I've vented the system pretty well and it works fine.
But, the pressure gauge on the boiler doesn't seem right to me. The pressure gauge ranges from zero up to 30 psi, and reads 7 psi even when the boiler is cool. Do I have the wrong gauge? A broken gauge? Do I replace it? I'd like some advice. Thanks.
You either have a bad gauge
or the pigtail under the gauge is plugged. Replace the bad part.
gauge on boiler
The Pressuretrol is mounted on a pigtail. But, the gauge I'm talking about is next to the Pressuretrol and is marked "Internal Syphon. It's just a dial. It has no pigtail and is mounted flush against the boiler.0 -
Then it's the gauge
replace it. Since you may not be able to find one with the internal syphon, get a new brass pigtail to mount it on.
Most steam boilers seem to come with 0-30 psi gauges. These gauges are virtually useless if you run .5 cut in and 1.5 psig cutout. The boiler pressure relief valve will blow at 15 psig. My brand new gauge (which came with the boiler) barely moves when the boiler runs.
I bought a 0-5 psi gauge at the local supply house and installed it. It works properly by confirming my pressuretrol settings (cut-in and cut-out).
Dan0 -
code
YOU should add a 30# additional gauge to comply to code.0 -
Code requires the gauge
to read twice the boiler's maximum allowable working pressure, which in the case of residential steamers is 15 PSI. Note that this requirement has NOTHING WHATEVER to do with the pressure requirements of the system that the boiler is connected to.
The reason for this is, apparently there were boiler explosions in the old days where the gauge was indicating zero pressure. In these cases the boilers were so over-pressurized that the pointer on the gauge moved all the way around back to the zero mark. Having the gauge read twice the MAWP made this less likely.
There's nothing wrong with having a 0-5 PSI gauge on a residential steamer to show the actual pressure, but the 0-30 PSI gauge must remain to satisfy Code.
gauge
I neglected to mention that I did leave the 30 psi gauge on when I added the 5 psi gauge. However, I dropped the 30 psi gauge on the floor and it now reads 4psi even when the system is off. Yes, it is time for a new gauge (useful or not)as code requires it.
Dan0 -
Cool
Watching that low pressure gauge hit the cut-out and cut-in pressures would inspire nostalgic visions of shifting to the tachometer on my college-era Triumph TR-4. Yeah, I gotta get a low pressure gauge. Plus comfy chair, pin-up posters, beers...0 -
Looks like
Too much pipe dope to me. Could have plugged the pigtail.
Used to pull them and clean during annual cleaning.0 -
gauge
Oh, for those carefree college days!
Nowadays, when my wife notices that I am "playing around" with the boiler or watching the pressure gauge move, she suggests something "more useful" like taking out the trash or chopping ice off the driveway.
Dan0 -
too much dope
You are correct. I overdid the pipe dope. I was over-compensating for my previous use of leaky "street els" (as opposed to 90'regular elbows) which strip and leak even with pipe dope on them.
In the end,I used only Tees (which did not strip or leak)and nipples to mount the gauges. As the pigtail is not plugged, I will clean this up after heating season when I add a vaporstat.
Dan0 -
where
can I buy such a low range gauge?
I went to various home depots, lowes and even mom and pop shops. Can't seem to find any at Pex Supply either. I live in Brooklyn, NY area by the way.0 -
bklyn suppliers
try H. & L. Supply on coney island ave bet. ave H & foster or davis & warshaw could order for you if not in stock. branch also on c.i. ave & ave I0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
