Hot water pump from a steam boiler
Joe Gaetan
Member Posts: 6
My neighbor has a one pipe steam heating system in his house.He built an extension in his basement and since the boiler is there he can't install a steam radiator.What they did, they installed a pump by the boiler and this pump circulates hot water to a hot water radiator in the new part of the basement.It looks like it is hooked up by the return pipe,and it has its own thermostat which is actually a temparature controlled switch.I have never seen
anything like this,is this legal or mechanically correct? Thanks.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
