how hot??
Ken_40
Member Posts: 1,310
212 degrees F is the simplest of answers.
No where hot enough to:
scorch drapes made of cotton, paper, linen, wooden furniture, furniture upholstery, etc.,
But WILL damage:
candles, crayons and your skin - if left in direct contact.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=504&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
But WILL damage:
How Hot ?
Hot hot in degrees does a steam radiator get while operating?
Depends
Irv,
Anywhere from room temp to 215 degrees fahrenheit.
It varies depending on sq ft of iron (size of radiator), piping, distribution (vapor, low/high pressure, vacuum, wet/dry return, one or two pipe), rad location, capacity, boiler capacity, burner size, inlet valve, venting, t-stat location, and so on-0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
